I have a battery bank consisting of 2 8D 12v Lead Acid batteries in parralel and an 8 D engine starter battery. I have configured my Multiplus 3000 50 Amp inverter/charger to charge my batteries at 14.4 during absorption phase and 13.6 at float. What I am noticing is that during my Bulk charging phase, it is charging around 13.9 + and then it switches to 14.01 and creeps up to 14.38 or so during Absorption and Float. Different than the settings I have programmed through the VE.connect interface with my computer. Where would these other voltage values be coming from and does the difference hurt my batteries?
water_rat
(klim8skeptic)
2
Sounds like battery safe is working to minimize battery gassing.
Have a look at the charge algorithm section of the manual.
Related topics
| Topic | Replies | Views | Activity | |
| Multiplus II loads battery to 57 volt, although 3.45 / 55.2 has been defined | 9 | 90 | 26 April 2026 | |
| Multiplus II 12/3000/120 strange behavior? | 10 | 237 | 17 November 2025 | |
| 3xMulti plus 8xMPPT plus 2xDIY batteries - setup for voltages (bulk, absorption, float) | 4 | 186 | 8 October 2024 | |
| New Multiplus Goes Crazy in Absorption With New LiFePO4 Battery | 12 | 864 | 4 November 2025 | |
| Issue with MultiPlus Compact 24/2000/50: Charging curve stuck in bulk phase | 23 | 358 | 20 February 2025 |
