MultiPlus 2000VA as storage
Hi everybody, I ordered a MultiPlus 2000VA and my aim is to store energy coming from solar panels as in the picture.
the questions are:
  • the picture is relative to Multiplus II, would it work with MultiPlus 2000VA in the same way?
  • only few devices will be connected to the essential load, would energy coming from battery also power the loads connected to the other AC loads keeping the comsumption measured by the energy meter close to 0?
Yes.
It can contribute if you set it up like that. But not above its inverting power
Where are you from?
For most countries the 2000VA doesn’t have the certification to be used for ESS.
Only the MultiPlus-II models have that certificates.
Thank you for the answer,
I live in Germany, should I cancel the order and take another?
I was just wondering about that. Thanks for saving the time on the research.
If you want to install and register it officially than you need a MultiPlus-II they have all needed certificates.
