MultiPlus 12/1600/70-16 shows “Fault / Störung” and stops charging – no alarms
I’m having an issue with my Victron MultiPlus 12/1600/70-16.
This is the second time it goes into “Störung / Fault state” and completely stops charging.
The unit is about 3 years old and has always worked fine until now.
What’s strange:
  • All alarm statuses show OK
  • No VE.Bus errors
  • No notifications or logs in VRM
  • Battery voltage is normal (~13.2 V)
  • Charging/discharging are allowed in VE.Bus BMS
I can’t check the LEDs, as the camper is far away and I’m controlling everything remotely via VRM.
I’ve attached a few VRM screenshots.
Any ideas what could cause this without visible alarms or logs?
Thanks!
Hier gibt es auch einen deutschen Bereich, da bespricht sich so was normalerweise einfacher
