Dear All ,
I would like to know if its possible to have multiple MPPTs on 1 system.
Because I have some 50V 550W panels that can’t be handled by the biggest MPPT as a string , nor as a series.
Let me know if I can split them in half and use 1 string of 3 on one MPPT and another string of 3 on an other MPPT.
Thank you in advance
The hellios
Netrange
(Steffen)
6 December 2024 19:27
2
Of course you can do that. That’s what we all do with our Mppts … there are also several on one system
What kind of Mppts do you have?
At the moment I have a small one that can handle 1000W.
SmartSolar Charger MPPT 150/35 that I realised thatis not enough for my setup.
So I have to buy 2 X 250/100 to be able to handle a 3.3KW system
As per the calculator of victron
Thanks
Netrange
(Steffen)
6 December 2024 20:40
4
The Mppt 250 may be a little expensive, but you can’t run 3 x 50V panels on a 150 Mppt. So you’ve done everything right. You can now run 4 panels on the 250 and keep the 150 in reserve.
Planning to have 3 panels on each 250 MPPT.
I have total of 6 Panels of 550W each at 50V Open Circuit Voltage.
I will be able to total the whole 3.3KW and keep some headroom ( reserve )
Netrange
(Steffen)
6 December 2024 21:04
6
Then the two 250s will have a relaxed life
Netrange
(Steffen)
6 December 2024 21:09
8
Have you already bought the two 250s?
Not yet. But they are in the planning phase . Do you have to suggest something else ?
Netrange
(Steffen)
6 December 2024 21:14
10
Use 3 x 150er mppt … 2 panels on each 150 … cheaper and the same power …
You will need to account the wiring too…
More or less will be the same price in the end.
Plus I want to keep my setup neat.
Having 3 MPPTs would take too much space and having a bigger distribution board… Etc etc.
I think it worth the investment. But I will look into your solution and decide in the end what would be best.
Thank you though
Netrange
(Steffen)
6 December 2024 21:22
12
It’s your blue universe
BTW : you could use 2 x 250/ 70 … each 2kw PV …
only 185x250 mm
the difference is 109 euro on each
between 250/100 and 250/70
I think going down in amperage for 109 euro is not worth the time. nor effort.
I will need to get bigger busbars anyway so it’s worth it I think.
But I am waiting on a price from the local dealer sometimes prices vary a bit from the price catalogue vs reality
and of course a USB to VE.CAN adapter.
Netrange
(Steffen)
6 December 2024 21:43
15
Why this adapter ?
It exist an (old) Ve Can to USB Adapter …
normaly you use a VE-Direct to USB Adapter
This works with RPI and every bitrate possible. 500 and 250 kbit/s
Tested it with a BMS.
and this
here is the selection of bitrate ( depending on the protocol and bus you will use )
here is from the Victron’s professional video
Netrange
(Steffen)
6 December 2024 21:46
17
Ah … ok … you use a Berry GX … OK
German Amazon Suche … also ein Mitbürger
I will disappoint you on that , I am not German, I just order from German amazon because its the one mostly shipping to my location
Danke
owenb79
(Owen)
6 December 2024 23:17
19
You should just go for the 450/100. You will not regret it. Stay away from the non-isolated controllers for big systems.
Unfortunately only as a 48v system.
I am running a 24v system
