I am working on a schematic where the customer has installed 3 MPPT 100/30 in parallel feeding the same positive busbar. So they are at the same potential on output. How is that affecting the global efficiency of the system ?
My understanding is that if one array has a higher output, it will block the two others (limited mode).
That is also what can be observed when the circuit voltage is driven by generator or alternator.
Is there a way to make the 3 systems to combine their output ?
