Hi there,I’ve got bifacials with 49.55V open circuit voltage and 13.85A Short circuit current.This is without the bifacial gain .My panels would go up in “best conditions” to 675 Wp.Oversized,because the Multi RS only takes up to 3kw per MPPT.Most important is not to go over the max. MPPT voltage,which is 8x the Float Voltage of your Battery bank(s).cheers Frank
there is a video on the Vicron professional site, where Guy Steward discusses the Multi RS.
the 16A short circuit rating is only for reverse polarity connection.
The multi rs can only draw 3000w per mppt, even if you have a 50kw pv array on your roof, the multi will only request 3000w from the array at max. you just have to make sure that the pv voltage at 3000w is at a reasonable current. ie >200Volts (200v @ 3000w equals 15A)
a pv array cannot “push” current into the mppt, current flows when there is a demand for it
