MQTT Connection to a "secured" Cerbo-GX
Hello everyone.
I have some questions about MQTT and TLS.
When I switch my Cerbo-GX v3.53 to TLS, it brings up some problems and questions:
  1. When I switch the MQTT Explorer to port 8883 and enable TLS, the encrypted communication already works without a password, username, and certificate. Where is the additional security here? Why is no certificate provided, and why are no username and password required?
  2. When I try to include the encrypted Cerbo-GX in an MQTT Bridge, it does not work. I use an Eclipse Mosquitto MQTT Bridge and am very satisfied with it, but I cannot integrate the encrypted Cerbo-GX. The unencrypted Cerbo-GX works very well. Again, I am either missing a certificate or password and username.
The configuration for the bridge looks like this:
per_listener_settings true
allow_anonymous true
persistence true
persistence_location /mosquitto/data/
log_dest file /mosquitto/log/mosquitto.log
log_timestamp_format %Y-%m-%dT%H:%M:%S
log_dest stdout
log_type all
## MQTT Secure listener
listener 8883 0.0.0.0
require_certificate false
tls_version tlsv1.2
# MQTT Default listener
listener 1883 0.0.0.0
# MQTT over WebSockets
listener 9001 0.0.0.0
protocol websockets
connection victron
address 192.168.133.71:1883
topic N/# in 0 victron/
connection victron-tls
address 192.168.133.71:8883
topic N/# in 0 victron-tls/
bridge_insecure true
tls_version tlsv1.2
connection openWB
address 192.168.133.79:1883
topic openWB/# both 0 openWB/
connection watermeter
address 192.168.133.90:1883
topic watermeter/# in 0 watermeter/
My error message:
2025-01-25T16:03:54: Connecting bridge victron-tls (192.168.133.71:8883)
2025-01-25T16:03:54: Bridge eclipse-mosquitto.victron-tls sending CONNECT
2025-01-25T16:03:54: Client local.eclipse-mosquitto.victron-tls closed its connection.
My interpretation: If the simple configuration without a certificate, password, and username works with the MQTT Explorer, shouldn’t it also work with the Mosquitto Bridge?
Does anyone have a working bridge configuration if the Cerbo-GX configuration is set to “secure”?
Hi Marc,
got about the same problem on my side. Unencrypted communication works like a charm. I can also get a connection & data connecting via MQTT Explorer to my Cerbo GX, but cannot configure the Mosquitto Bridge to work the same way.
My log looks like yours:
2025-02-02 12:44:16: Connecting bridge victron (192.168.1.10:8883)
2025-02-02 12:44:16: Client homeassistant closed its connection.
Regarding your communication without password: Are you sure that the connection is properly reset? I sometimes do get more MQTT data for a while after switching to secured communication in the Cerbo GX.
Hey guys,
I’ve maybe found a solution.
  1. get the certificate from Cerbo echo | openssl s_client -connect venus.local:8883 2>/dev/null | openssl x509
  2. save the CA into HomeAssistant
  3. use this config (you can remove credentials if you do not use them)
connection victron
address venus.local:8883
remote_username victron
remote_password YourPassword
topic R/# out 0 victron/
topic W/# out 0 victron/
bridge_tls_version tlsv1.3
bridge_cafile /share/mosquitto/venus.local.crt
  1. you can test the connection from your computer as well mosquitto_sub -h venus.local -p 8883 -t 'N/#' -u victron -P YourPassword -v --cafile venus.crt
Fanda36 thanks so much for your post. Your solution got me on the right track. I had to add a couple of options in my victron.conf file on HomeAssistant.
connection victron
address 192.168.1.111:8883
remote_password MyPassword
bridge_cafile /ssl/venus.crt
bridge_protocol_version mqttv50
cleansession true
I kept getting various errors without cleansession true and bridge_protocol_version mqttv50
Just in case anyone is searching for a solution the errors I got before adding those options were:
In the Home Assistant Misquitto Broker log
2025-03-23 00:40:10: Connection Refused: Not authorized
On the Venus GX (Raspberry Pi 4) in /data/log/flashmq/current
[2025-03-23 07:40:10.215] [NOTICE] [T 0] Removing client '[ClientID='core-mosquitto.victron', username='victron', fd=21, keepalive=60s, transport='TCP/SSL', address='192.168.1.111', prot=5.0, clean=1]'. Reason(s): Cannot take over session with different username
Or
[2025-03-23 07:15:36.276] [NOTICE] [T 0] Client '[ClientID='core-mosquitto.victron', username='victron', fd=21, keepalive=60s, transport='TCP/SSL', address='192.168.1.111', prot=5.0, clean=0]' logged in successfully
But, there wouldn’t be any new messages published in the Mosquitto Broker on Home Assistant.
After reading a little about FlashMQ and cleansession Understanding clean session and clean start – FlashMQ
I added cleansession true and now my HA can read the bridged MQTT data. I’m up and running with Home Assistant and Firmware v3.54!
Just to say thanks for the solution
The only (noob) issue was not realising that the certificate is created on screen and you must copy that into a file
I found the File editor add on in Home Assistant useful as you can upload files easily
