MP2 12/3000/120-50: A generator is supplying an RV trailer with 120V air conditioner. AC input limit for Powerassist set to 14A. When the air conditioner compressor starts, the Powerassist engages. After the compressor has started, the MP2’s AC output drops below 12A and AC input from the generator drops to 9A-10A. The generator could now carry the full load but Powerassist remains engaged. I understand that the Assist Current Boost Factor only affects the boost current for the first 50ms. What configuration parameters affect: (1) the ongoing Powerassist current amount so that more of the available supply current is used; and (2) Powerassist cutoff as soon as the AC output load drops below the AC input limit?
Bump.
I have this same question, situation.
This thread may be helpful, if you haven’t seen it already: Exactly how BoostFactor works? - #33 by JohannesBoonstra
