Monitoring victron lithium batteries remotely with VRM
I have a 45kva three phase battery pack. The pack contains 12x200AH Victron smart lithium batteries in a 3x4 series-parallel 48v configuration with the associated Victron lithium BMS hardware. These batteries are connected to 3xQuattro 15kw inverters setup in a three-phase configuration.
The battery currently has a colour control GX to monitor the inverters and the Victron smart solar MPPT charger and control the starting and stopping of a generator for battery pack recharging when solar is not enough. The installation is also monitored remotely using a Victron 4G modem connected to the VRM portal.
I can connect to individual batteries while on site with the Victron connect app via Bluetooth with my phone without issue to monitor individual cell voltages and check alarms
Is there any Victron branded product solution for remotely monitoring the individual cell voltages and any associated alarms of each of the batteries? Ie using a cerbo gx with its bluetooth functionality to connect to each of the batteries if thats possible?
