Hi all,
I have a GX device i have removed from my second multiplus unit that is running in parallel on my house.
I purchased 2 multiplus GX devices to have one as a spare incase one broke.
I want to use this device in my caravan which will have a victron setup. Essentially, i am wanting to get out of purchasing a Cerbo unit to collate the telemetry etc…
I have removed the PCB, and its sitting on my desk and i have connected my MK3 into the VEbus port on the PCB that would normally connect to (what i assume) is the VEbus port on the multiplus internal controller board.
However, it does not show up in VEconfigure.
The GX unit is configured as a mirror of my other unit, and i want to wipe its config and reset it to essentially factory.
My caravan will be all 24V and will have a Batrium BMS for the lithium (which i need a canbus port for to integrate it to control the chargers) and it will have some of the Victron MPPT controllers connected to the GX device using VEdirect.
However, my issue is that i cant get it to recognise the unit using the MK3. so seeking some advice on if its compatible to do this.
