I have a Lynx NG BMS & Wakespeed Regulator currently connected to Can Port 1 on a Cerbo GX Mk2 as per the Victron manuals & schematics. I want to connect the GX to a NMEA2000 network to bridge this data onto that network. I see from the Cerbo GX MK 2 specifications that CAN Port 1 is the only opto isolated CAN port available so would like to use that port for the drop connection to the NMEA2000 network. My question is will the Lynx NG BMS & Wakespeed function on CAN port 2 correctly? Is this layout acceptable to Victron? Thank you for your help….
Yes, with the Mk2 Cerbo you can program each Can interface individually.
But AFAIK you can use Can 1 for both VE.Can and NMEA2000 at the same time, since NMEA2000 is a simple toggle under VE.Can
Thank you for your reply and help.
