Lynx BMS system not shutting down MPPT
Hey folks so I’ve installed a few full 12v & 24v Victron systems with Lynx BMS and everything for the most part has worked flawlessly though its been a months since my last full Victron system. My question though, and this came up on this latest system, is when I turn off the Lynx BMS via a remote switch it does not turn off the MPPT charging. I noticed this when the system had turned off and the contactor had opened but the Multiplus lights were still on and my Maxxfan was still running, albeit incrementally because it was running on solar input. I have my 100/20 connected to the cerbo via VE.direct and it is verified “controlled by BMS” but it would not stop charging unless I turned off the solar input double pole breaker.
Is this normal behavior or am I missing something?
