Limit charge current overnight.
Is there a way on a victron multiplus II GX to limit the charge current between set hours, or overnight? but allow full current charging from solar if available.
you can program the battery charge current in the Multiplus to limit that. I think that this limit is not over-ridden by the gx, solar charging should still work at full rate.
