Hello.
Please advise. I have a simple set up. Mppt. Cerbo gx. Phoenix smart IP43. Victron smart inverter. And two AGM 230Ah.
I like to switch to lifepo4 and the pureAcell seems to work with Victron. Do I need to replace the IP43 for a multiplus in charger only mode to have the pureAcell bus BMS working together?
I will keep separate charger and inverter because we will always like to have a complete system always on inverter and not connect to grid.
