Lamps flicker when turn on the air conditioner
You mean 10kWh? What battery/bms is it? What are it’s specs and, if managed, the ccl and dcl?
Inevitably, the battery can be the source of these problems.
With parallel systems, you can also have asymmetry. Have you checked that they are balanced?
I have a flow in the nodered section that can show this in realtime.
