“CCL doesn’t affect discharging.”. This is true. However, CCL does control the MPPTs, which will do absolutely nothing while the CCL is zero. This is my experience from several systems. You are welcome to provide graphs to the contrary. NOTE: The context is an MPPT that is controlled by a battery BMS.
This situation is MPPTs with BMS override…but that’s not what’s causing the clipping in this case, although later in the day it will…as mentioned in one of my earlier replies a 3kW load is turned on at around 11:42 in the first chart and nothing changes about limiting or PV yield, Peter (battery charging) is just robbed to pay Paul (loads)…
It “might” produce zero, depends on conditions and your BMS/config. I am looking at several sites with commercial batteries right now, ccl is zero and mppts are producing. This is one with a modest load ~1000W being covered by PV.
I have not had a issue with mppts failing to cover loads with a battery that does not want charge. DIY batteries on the otherhand can be more temperamental
