I just bought two brand new 25.6volt 100 AH batteries and a IP67 charger. I charged the first battery and it showed only 67.3 amp hours on the battery, I thought maybe the new battery may be faulty, so I went ahead and charged the second one and basically have the same thing, it shows 66.6 amp hours. Is the IP-67 faulty, or do I need to get a larger charger? I have charger set to Lithium ion setting.
The batteries were about 33% charged when you got them and you’ve charged them both up to 100%, so added approx 67% to each. What is the problem?
Well……Obviously I thought the charger was showing total AH for each battery, and not how many amp hours it “added”. So thank you for clarifying, and now there is no “Problem”….
Kind of a smug smarta$$ are ya?
You’re welcome.
