Inverter VE.Direct 1600W to drive 1.5HP air compressor
We would like to use the VE.Direct 1600W with the 1.5HP air compressor. Does the inverter can handle the starting current of the compressor?
Unlikely. Look at the kW / kVA rating, Calculating the kW rating, this is about 1.2, allowing a start factor of x6, this is looking like a starting peak power of ~7kVA, whereas the inverter is around 3kVA peak.
