Inverter not turning on
I have a 5K MultiPlus II, it sometimes does not turn back on after turning the switch off. The Battery is 87% and charged at 54.25V
I do not have the inverter connected to 230V AC. It is only connected via the battery.
I have been able to get it back on by turning off the battery supply and disconnecting the VE BUS cable, and waiting for 5 to 10 minutes.
The inverter does turn on, but I am not sure what is causing the problem.
I see that the problem might be that the connected VE BUS cable is causing the problem.
What I cannot find is what the solution is.
Is there an easy fix to this?
Thank you
A post was merged into an existing topic: Multiplus-II inverter not switching On with VE.Bus cable to Cerbo GX Connected
