Integration of combined heat and power unit
Our home is heated through a combined heat and power unit, namely a Senertec Dachs. It is controlled by heat requirement and produces 12kW heat and 5kW of electric power.
Furthermore we installed a Victron Energy ESS system including 3 MultiPlus 2 5000, Cerbo GX, RS450/200 and VM-3P75CT as energy meter.
The Senertec Dachs is connected on the AC In side of the MultiPlus. Furthermore, we require a cascade of power meters to measure Grid feed-in from PV and the Dachs separately, as they are paid with different prices.
A VM-3P75CT also measures the power production of the Dachs, and we get that information into the GX device. We configured the VM-3P75CT role as a generator. Unfortunately, we can not configure the position due to the role selection. But we do not like to get the different energy productions of PV and Senertec Dachs mixed.
The energies are properly tracked with this configuration.
But there is no generator shown in the new UI and when the Dachs is running and producing 5kW of energy, this is properly charged into the battery but also shown as AC Load of 5kW, which is not correct. There is no AC load between grid and AC In of the MultiPlus. Every AC load is on AC Out.
How can we correctly integrated the measurement of the Senertec Dachs power production in the Victron ESS system and show it correctly in all displays?
Did you find any solution to your problem?
I’m thinking of adding another inverter to output of multiplus.
And want to use virtual generator when energy is flowing back from another inverter and virtual load when another inverter is consuming.
There is currently no solution for my problem. Only simple answer is to configure the energy meter to be displayed as an inverter. But having graphs with solar energy at night is very awkward for me.
A generic “AC Production” would be nice - I understand.
But first we’re going to finish what we’re working on now.
The problem with this is that its quite a lot of work to make it all work, including graphs on VRM and so forth.
Ps. Until then, best option is to select PV Inverter as its role; and accept that solar graphs on VRM are more like total generation graphs.
Same is for the requests to add an option to visualise AC coupled wind generation btw.
@mpvader Thank you very much for your response. Something like a generic AC production would be really nice. We used a PV inverter in the past for the combined heat and power unit, but that looks very awkward to have PV during the nights. Furthermore, it confuses the prediction a lot. For now, we keep it as AC generator and wrong current display, but long term graphs are fine. And we get separated production values for PV and AC generator.
