Increase AC-IN output based on EV charger power
My 3fase MultiplusII (MPII) system was installed with the ev-charger on AC-IN. In standard operations, this means that the (victron) ev-charger will pull from grid unless SoC is 100% and solar is feeding. Instead, I would like the EV-charger to always us battery power (unless SoC is below 20%)
I would like to make a node red script that does the following
If EV-charger is feeding into car with more than 100W (to iron out standard system oscilation) per phase
Then make MPII feed AC-IN with a similar power per phase
How do I get my converter to up its AC-IN output power? Which variable should I be looking for in node-red?
