How well is my ESS Configuration Working?
My Solar Solution:
1 x Victron Energy Quattro 48/8000 (Grid Tied – Single Phase)
1 x Cerbo GX with ESS for Self-Consumption
1 x Victron Energy RS450/100 Solar Charge Controller or MPPT
1 x 48V Freedom Won 10/8 Lithium-Ion battery
1 x Yamaha EF6600 Generator with 2 x 16A Outlets
8 x 345W Sunpower CPV Panels, S -25.88, Azimuth: North, Tilt Angle: 30°
I have recently 25/06/2025) configured ESS. There is a lot of documentation on configuring ESS but understandably very little on the exact or a range for the set point.
The settings: (from VEConfigure 3 Summary)
  • System uses LiefPo4 with other type BMS
  • Battery Capacity: 200Ah
  • Sustain Voltage: 50.00V
  • Cut-off voltage for a discharge current of:
    • 0.005 C = 48.00V
    • 0.25 C = 47.80V
    • 0.7 C = 47.20V
    • 2 C = 46.80V
  • Inverting allowed again when the voltage rises 2.00V above cut-off (0)
  • Relevant VE Configure Settings: (other than those mentioned above)
    • Power Assist: Checked
    • Dynamic Current Limiter: Checked
    • Storage Mode: Unchecked
  • Other Settings from VeConfigure 3
    • General Tab
      • Enable Battery Monitor: Checked
      • State of Charge When Bulk Finished: 95%
      • Charge Effiiciency: 0.95
    • Grid Tab:
      • Country / Grid Code Standard: Set for South Africa)
  • From ESS on the Remote Console:
    • Mode: Optimised (with BatteryLife)
    • Grid Metering: Inverter / Charger
    • Multi-Phase Regulation: Total of All Phases
    • Minimum SoC (unless grid fails): 80%
    • Active SoC Limit: 80%
    • Battery Life State: Self-Consumption
    • Limit Inverter Power: Checked
    • Maximum Inverter Power: 5,500W
    • Grid Set Point: 50W
    • Grid Feed-In: Unchecked
    • DC-Coupled PV – Feed in Excess: Unchecked
    • Feed-In Limiting Active: Unchecked
Is this enough information to give an opinion on the correct configuration?
What would the measure be of how well it works?
These are usually not checked, the latter is for generators only.
For the most part no one here can advise you how to optimise the system, only if the basic settings are correct.
An optimal config depends on your system size and how you use it, then tuning accordingly.
Your system is quite unbalanced, so there is no optimal config as it will always have trade offs.
You have a largish inverter, with a small battery and small PV array.
This means your ability to discharge the battery outweighs the ability to keep it charged, so it tends to end up with the battery cycling between charging and discharging, and often struggling to remain fully charged for sustained periods - something needed to keep the cells balanced.
At an 80% SOC, there is very little self-consumption available to you, so it will not be a very effective ESS.
The best you can do is to try validate that 80% is the right minimum SOC, but here in SA, as you are aware, you have to have enough juice in the lithium tank in case of an unplanned grid outage.
You will be able to determine how much PV you can reasonably generate, and offset that against your known consumption.
I would consider increasing the PV (assuming there is space to do so) and ideally adding another battery.
FWon have had issues pairing batteries, so if that is the plan, I would not leave it too late as time can make that harder to do.
@Saun, you mentioned South Africa and with 4.5 to 6.5kWh per square meter of solar panel, with 10-12 hours of sunlight, with SunPower panels (brand used by Nasa). Should be more than sufficient, but how much energy do you exactly produce during the day? In theory this could be something like 50-75kWh.
And if that 80% (8kWh of 10kWh left) is correct, set intentional, then I guess that you don’t need more power during the night?
No chance. I have almost 10kWp and get just over 40kWh in peak conditions, though orientation for some isn’t optimal.
You tend to lose around 1/3 so typical peak performance for his install is around 1900Wh.
I would estimate maybe 10-12kWh daily in ideal conditions, with a typical home consuming 20-30kWh daily.
To get 50kWh off a 2300Wp rated PV array, in peak summer you’d need over 4000W per hour, each hour from sunrise to sunset.
Sorry. I somehow mixed up his 10kWh with 10kWp and used the following data to get to the values:
For comparison. I only have 6.5kWp and harvest over 50kWh a day. With (micro) inverters clipping up to six hours a day. But that is with brand spanking new panels (25% panel efficiency) and 10.000km up north.
In my case It should be a lot more, I have architectural challenges so the inefficiency is an accepted tradeoff, though I do get a slightly wider generation window to offset the loss of peak power.
We’re peak winter currently, so lose around a third of peak generation, but at least being summer rainfall, we have beautiful clear, sunny days almost every day.
The same can’t be said for the coastal areas where generation is dire this time of year.
Winter:
Summer:
Nick, thank you for your reply.
If there is enough load and good solar radiation, 14kWh is possible even in winter.
Today has not been a good solar raidation day.
I have found this estimate to be accurate and and good guideline - I only have data from 05/05/2025 onwards, so I will have to wait and see.
The Unit of Measure for PV Power is incorrect. This should be kW.
14kWh is fair, you will have to offset against daytime consumption and charging to see what is surplus, that will give an idea of what your minimum SOC could be, not taking into account what you require for outages, but I presume you would charge from grid to restore min SOC.
Your best bet to use surplus power is to try load shift if possible, or use it to offset any pumps or water heating.
I definitely would not use battery life as already stated, use the other optimised option.
I would create a nodered flow to check your SOC at a set time, like late afternoon, and if it is below threshold to have it automatically top it up.
It is a more efficient way to create a personalised batterylife.
Just make sure the battery gets to spend a sustained period at 100% SOC at regular intervals. FWons like to drift if they don’t get to balance properly.
Thank you Nick.
I am trying to get a number for surplus for a 12 month period so that I can try and determine a business case for export / feed-in.
I will be using the estimates in the table. My gut feel without having gatherered all the information is that it is not worthwhile to feedback into the grid… and some other factors too.
LOL here it is the city council. Need a permit. Don’t get one for more panels due to breeding birds. Needed to get creative :wink:
Just FYI. If you are eskom direct there is no business case that works. Even local councils, aside from the Cape, don’t remunerate properly. Your best return is to offset your own consumption by storing as much as possible.
“Power Assist: Checked
These are usually not checked, the latter is for generators only.”
Yes, I have a generator – Manual start and connection.
“For the most part no one here can advise you how to optimise the system, only if the basic settings are correct.”
Thank you. Are the basic settings I have posted correct?
“An optimal config depends on your system size and how you use it, then tuning accordingly.”
System size is mentioned. If anything is missing, please advise. Community members will be limited in the responses where adequate information is not provided.
“Your system is quite unbalanced, so there is no optimal config as it will always have trade offs.”
I would like to know if there is a Victron Energy specification/ guideline / best practice for “unbalanced”. I have not seen any minimum and maximum combinations in a datasheet. If there are, please share the link / information.
“You have a largish inverter, with a small battery and small PV array.”
I have had loads peak at 6kW. On a good solar radiation day (recently), the SoC can go from 80% at about 07:00 to 100% at 10:00 with no serious loads. Solar power at this time of the year (27/06/2025) started trickling in the 07:00 – 08:00 slot on the VRB Dashboard System Overview bar chart. Battery Min/Max: 83 – 99% in the 09:00 – 10:00 slot. The 100% SoC is being reached daily weather perimitting.
“This means your ability to discharge the battery outweighs the ability to keep it charged, so it tends to end up with the battery cycling between charging and discharging, and often struggling to remain fully charged for sustained periods - something needed to keep the cells balanced.”
How long must the battery be fully charged for sustained periods? How many hours a day?
Cycling (Charge mode and then inverter mode) – this used to happen before ESS was configured and uploaded. ESS does not appear to work that way and reverts to the grid when the 80% SoC is reached. Very little is discharged from the battery. I was 50W this morning when the SoC was 79% and ESS #1 and #2 were active.
“At an 80% SOC, there is very little self-consumption available to you, so it will not be a very effective ESS.”
Prior to installing ESS, the inverter would cycle between Inverting (solid green LED on the inverter) and Charging. Left hand side LED’s would come on for charging and bulk.
This is not the same with ESS. At that time the Charging a LED would go on and the Inverter LED would go off. Once the SoC go to about 95%, Charging would go off and it would revert to Inverter. This is the cycle it would follow.
“The best you can do is to try validate that 80% is the right minimum SOC, but here in SA, as you are aware, you have to have enough juice in the lithium tank in case of an unplanned grid outage.”
The SoC did not drop below 79% last night and was drawing up to 500W from the grid at times. That leaves some power for when outages occur.
“You will be able to determine how much PV you can reasonably generate, and offset that against your known consumption.”
My estimate has been included in this thread in a reply.
“I would consider increasing the PV (assuming there is space to do so) and ideally adding another battery.”
Yes, there is roof space for another 3kV PV and the RS 450/100 can handle two strings / trackers. I might have to change the way the strings are put together.
“Freedom Won have had issues pairing batteries, so if that is the plan, I would not leave it too late as time can make that harder to do.”
Another Freedom Won 10/8 would be great when the budget permits. Thank you for the advice.
It appears that the business case for Eskom will be marginal if any. What my concern is that I will be forced to go from a HomePower Standard package to HomeFlex 1. I am trying to understand the multi-layered pricing structure and apply it to current log data so that I can get a better understanding.
If you’re sharing the input with grid and a genset, that limiter setting can have issues when on grid, typically this is where a quattro would be used.
3.60 allows multiple inverter configs to be kept and pushed to the inverter (does require a restart), so you could manually, or potentially automatically c/o nodered, change settings when needed, if it becomes an issue.
If Eskom regs stand and a tariff change is forced, you will only ever pay more. The daily rate is higher, they force time based tariffs that increase at peak times. Your exports are only credited against actual usage in the same time period, and not against daily fees. Typically you don’t need grid in the period you have surplus power, so it only helps if there has been bad weather or higher consumption. For the most part it is entirely for their benefit and your disadvantage.
My plan to avoid the regs is to move inverters off grid and to move the grid connection to a standalone 48V DC charger, unfortunately Victron don’t make one.
As far as your settings go, the basics all look good, so it is really about massaging how/when you want to charge/discharge and adjusting those limits, and, possibly to control some consumers based on available battery and PV.
The easiest way to do this is via an automation suite of your choosing, HA or nodered being popular.
Thank you for you feedback and valuable information.
