How to set the default installation in VRM portal?
is there any way to set an installation as default? I dont want to select my installation every time i go to the VRM portal. If I really need to access the other installation(s), I can still go back to the overview.
Thanks
Hi Pamapama,
I completely agree with you. So, once again, the question: Is it possible to jump directly to the favorite installation when opening the VRM portal if only one favorite is set? It’s really annoying when I have to select my main installation every time.
Thank you very much.
