How to Exclude AC-Coupled PV from ESS Peak Shaving Limit?
I’m planning to clone your settings because I believe the 50.2–52.7–53 curve accurately represents the PV powershift. Victron will indeed be able to shift over the full range, but our PV system won’t support the entire range and will shut down prematurely since C10/11 forces a shutdown at 51.5 Hz.
To correctly determine the appropriate frequency response, the entire curve needs to be configured.
If I were to set my minimum frequency point at 51.5 Hz, it would steepen the curve significantly and lead to inaccurate lookup points.
