How to connect two Fischer Panda and two Quattro parallel together
I want to use two 10000x Fischer panda and two 8KvaQuattro connected in one system. This is possiable ? How to connect these two Fischer Panda gensets into a GX device ?
From a quick analysis, these generators can’t be connected in parallel so your only option would be to run each Generator + Quattro individually.
As in: two separate systems.
