How to add a schedule in node red
So I figured out how to control relay number two with SOC… But for the life of me I can’t figure out how to add a schedule to it also…
I have relay number two turning off at 100% SOC and on at 96% SOC but I only wanted to do that during the day…
Any help would be greatly appreciated
Thanks
Scott
Build your flow to use an inject node to trigger it, you can configure the inject node to run during specific times and at specific intervals.
Not sure I even know how to do that lol
Does the inject go INTO the switch?
This is what I have now.
SOCrelayControl.zip (883 Bytes)
Easiest way is to put the victron node on its own, connected to nothing, then replace it with an inject node that sends the global variable that the victron node is automatically storing.
