Finally someone explains how to install Victron home battery.
Might be a good break down but by far from a how to. Too many regional codes to adhere to in order to under take a one fits all video. This is more of a typical overview and would say if your using the video to complete such work dont start the work! Victron themselves have manufactures guidence on how to typically install there equipment but you still have to follow area and regional guidelines. Victron Professional Portal has what you need to safely complete and understand what you are typically doing during and install but you must also follow Area/regional codes.
On the professional portal you will find nothing about AC side only DC.
For Netherlands it is now clear how to AC install it, I almost did it the correct way, I only have to lower one fuse from 50A to 40A.
As said depends where you are what you supply amps are what device you are using to what MCB RCBO rating you use. But the AC side is fairly straightforward as it’s more on building regional code and how the Multi is positioned ie like a gateway device just input wired to shave power rather than whole home backup.
But glad you managed to find someone in your use case situation, when your done you can post a pic to show your install in the shown us your install bit, so many people with some really nice installs. All the best
