How many faults until shutdown?
Hi all.
Question on a Multiplus II: How many attempts will it make to reconnect to grid after low voltage? I would have thought it will always try. However, we notice that after some time even if grid recovers to 240v it will stay in Fault state. Sorry can’t find any documentation on this so I reach out to you experts here.
It is set to Charger mode only to charge some batteries when network is within parameters.
Thank you.
In many places along Victron manuals, the fault recovery is tried for 3 times and then the device is staying in fault mode until the power is cycled.
Do you know of a way using node red, etc. to reset it out of fault state?
(Salutare!)
Salutare,
Also in manuals it says that the physical button should be used to reset the fault state. So, a cold (re)start.
Through Node-Red you can only do a soft (re)start, because the physical power button is in the On state.
