How do you get more detail in Alerts?
Hello, first big boat trip with my new Victron Config/installation on my 55’ motor yacht. This morning I received an Alert via email about an overload on one of my MPII Inverters. The Alert cleared after 20 seconds and I suspect it was a spike/load from my wife using the Microwave, toaster oven, and coffee maker at the same time. Problem is the Alert contains very little detail. Is there any way to get more detail in the Alerts?
Overview pic of the components in my system, Alert originated from Cerbo regarding my first MPII
Alert came via Email which I didn’t see until an hour later:
Cleared after 20 seconds:
My MPII’s are 5KW and are configured as an out of phase pair, each generating 120VAC 180 degree’s out of phase. We could use them for 240VAC but we only run 120V loads on a pair of 5KW Inverters so it’s hard to believe we were pulling more than 5KW on one inverter but without detail about how big the Overload on L1 was I’m left wondering how big was the OVERLOAD? Would love to know what was the load on L2 when this Alert occurred. I have seen spikes to 4KW with the Microwave and coffee maker on. Similarly the Coffee maker and Toaster oven are on the same 15amp breaker so if we are brewing coffee and toasting a bagel the breaker trips.
I logged into VRM thinking there must be more details there but this is a perfect example of my Ask how do we get more details in the Alerts. Notice these two Alerts don’t tell you anything about what caused the Alert to be triggered. How big was the Overload that was detected and for the Alert two weeks ago what was the SOC that caused that Alert?
Before submitting this new Topic it occurred to me VRM might have a graph of the Overload but 1500Watt Spike at 7:57 shouldn’t be enough IMO to trigger an Alarm, Battery SOC was 65% and Voltage dropped to 26VDC but that’s all healthy levels…
Scott on M/V Mariah on the way to the Bahamas…
The logging is every minute.
The spike may have happened somewhere in that. Its possible that the inverters did overload but the data capture & graphing smoothing doesn’t help with the visual representation of it.
Try downloading the csv data for a bit more detail.
Watts also isn’t a good way to look at power sometimes the power factor of the load plays into the inverter overload situation alot.
Look more at volts and amps.
I have for example seen a 1500watt lawn mower overload a 10kVa. (I know your wife wasn’t using one on the boat :upside_down_face:)
LX thanks I’ll look at CSV export but how about an enhancement request to have Alerts include more details like the values that caused the Alert to Trigger? After posting my thread all sorts of similar Alert Threads start appearing in my browser, many in Dutch or German not sure which but my point is many people seem to be asking for more Alert details to identify the root cause of the Alert.
Is this something that needs @mpvader eyes to approve as an enhancement request? You don’t call 911 to report a Fire without including some details like the location of the fire, is anybody hurt, etc. Similarly an Alert with no details is not very useful IMO…
As a side note LX your Generator Start Node-Red thread has been working perfectly for my AC Shore/Generator power connection logic!
Scott aboard M/V Mariah on the way to the Bahamas…
Agreed, alerts without values r just noise. Hope Victron adds it. Safe travels to the Bahamas
