How do I bond my neutral and ground for my new inverter?
Hi all
So i’ve just installed a new victron 12/3000va smart inverter however im not getting any power from it.
Ive kept it simple and have the AC wire running directly to a blue sea control switch, which then goes to my circuit board.
I know the AC side is fine as the shore power works fine with nothing tripping etc, yet when switch to inverter the reverse polarity light shows and i receive no power.
Its wired correct on the inverter, and i have unplugged the shore power and also tried with no avail.
I rewired the shore power to the where the inverter was wired on the switch, and again all worked correctly eliminating any issues with the switch.
So this has now blown my little mind, i dont want to just reverse the live and neutral in fear i will actually do some damage.
The only other thing i have read it coul be is it needs a neutral to earth bonding relay, which what even is that? And before i go out and purchase one is this the likely cause and any info on installation would be much appreciated.
Thanks in advance
Keiron
(Below is the switch panel the inverter is wired into)
These are built into the inverter and activate (if it was not disabled in settings) when switched to inverter only or mains is disconnected.
If you disconnect acin and ac out. Does it power on?
