How can I achieve a proper SBU setup with a Multi RS?
Hey everyone!
How can I achieve a SBU setup with the Multi RS? My use case is this:
  • During the day use solar to power the AC loads and to charge the batteries. The grid in AC IN should be completely disconnected, no feed-in, no charging batteries from it.
  • When the sun is gone, use the batteries to power the AC loads. The grid should still be completely disconnected, no feed-in, no charging the batteries from it.
  • When (if) batteries drop to 15% SOC during the night, only then use the grid to power the AC loads, but still no feed-in and no charging batteries from it.
Relevant settings in the Multi RS:
General → Mode: On
General → AC Input type: Grid
Grid → Grid code: None
ESS → Ess mode: Optimized without battery life
ESS → Minimum discharge SOC: 15%
ESS → Grid setpoint: 0W
The problem is that I still somehow pull from the grid during the day, even if it’s only a couple of Watts. I’m thinking of using the AC input control settings but wouldn’t those settings overlap with the ESS settings? If I set something like:
AC input control → Connect when SOC drops below: 15% (should this be 1% above ESS → Minimum discharge SOC??)
AC input control → Disconnect when SOC goes above: 20% (for example)
Would it work for my use case? Would those settings clash with the ESS → Minimum discharge SOC somehow?
Thanks!
It would work and not interfere with ESS. This is how it works in my case.
And, true, set BOTH “ESS minimum discharge” and “AC input control connect when SOC” at desired % plus 1, so 16% for 15%.
Just that the 15% is pretty low… In case of a blackout, it’s better to have some juice in batteries. I have it at 30% (31%, in fact :wink: )
Thanks Alex!
I did some experiments today with the AC input control percentages and it’s clear now. This is the second time you resolve one of my doubts. And I’ve come across more advice from you while researching about the Multi RS. @Victron should send you some free equipment, or at least a blue t-shirt, for the work you do here!
