Home assistant connection not working properly
It seem to be working with “current state”, although I had the issue yesterday it would use a old value?
After restarting nodered it used the current value, this will surely happen again.
using “events: state” node seems to be a bigger problem: States are not coming through or very sporadic.
Enabling heartbeat did not solve anything and I can see that nodered seems to reconnect every once and a while to home assistant. (even before heartbeat)
Connecting without SSL seems a BIT better but no real improvement.
Any thoughts / tips?
All wired network connection <1ms ping to both, no drops.
