Hello !
I have an EasySolar II-GX 3000VA 24V 250/70 with two LiFePO4 25.6v 100Ah batteries and 1200Wc solar panels.
Last night a few things happened that I don’t really understand, I plugged an AC input around 17h (5h PM), at this time it seems the MPPT was ending Bulk phase, but the sun was almost down, I also plugged in a 2000w electrical heater.
First thing : around 17h20, the MPPT went into fault (Err 38) this default cuts solar power in order to prevent over-charging, from data it seems the mppt was going into absorption but went back to bulk before going into fault.
I’ve always been puzzled by the visible absence of communication between the Mppt and the Multiplus II (both parts of the Easysolar), when I plug in an AC input it seems to trigger a charge, no matter what the status of the mppt is…
Here are the readings :
Global for the night
Solar input around Fault
Solar/Battery around fault :
MPPT state :
My second issue : As visible on the first screenshot, it seems there was a tension surge at 3:33, from the AC readings it appears to have happened during a period of low consumption, any Idea what could cause this ?
Here are the readings:
AC consumption :
Battery :
Thanks!!!
