Help please
I have starter battery, and 3 Ah lithium batteries connected in parallel. I want to connect the smart shunt and the dcdc and an inverter from the starter battery how will that look? With the intent of connecting a solar panel as well.
You would best be served doing a little research on the products. Especially for fuse and cable siIng.
There are some sample schematics available on each product page.
The forum is not a place for system design. It is in the community guidlines.
If you drew something on a piece of paper and uploaded it we can crtitic it and help you, tell you what you may have missed, but definitely not the other way around.
Also the capacity or voltage here?
What size/model?
Or are you just looking for a power flow?
Hi Leah1. This is an excellent occassion for contacting your closest Victron distributor or installer. You can find them here: https://www.victronenergy.com/where-to-buy
Good luck with your project!
