HAM Radio Repeater on a garden yard
Have a garden yard with ant theres is running a HAM Radio repeater DO0TEK .
3x SmartSolar 100/20 2x 335Wpv and 1x 425Wpv module.
Multiplus 12/800 , BMV702, SmartShunt for DC load and raspberry-pi 3.
6 used truck batterys that we received as gifts, 810Ah
By Markus
DO0TEK is the new sister of DB0TEK @QRG: 439,250Mhz -7,6 MHz?
My 70cm Antenna is down since the setup of solar modules but I should hear Kirchheim-Teck here in the Remstal very good. Hopefully the few moduls last over the winter month
The idea for the repeater was born at the end of 2018 before DB0TEK started operations. At that time there was still DB0WN on 145.650MHz.
After observing the 439.250MHz frequency for a long time, I applied for approval in January 2020 and received it in July 2020.
DO0TEK is connected to the echolink network EL#582439
Nice system, I noticed that you have 3 x MPPT, have you connect one PV panel to each MPPT?
one PV panel to each MPPT, each panel has a different orientation.
