GX Screen have some sort of screensaver
Dear all,
When there is an alarm, for example low batteries alarm, I can remotely affirm that alarm, through the VRM. Though often I find the GX monitor (GX Touch) still reporting the alarm. And the screen is than on all the time, on the messages-screen.
This is very logical, because when you walk past your system, you see that something is off because of the GX monitor being on.
My suggestion is a screensaver! Please implement some sort of screensaver.
It could be a transparent bubble moving over the screen (like the old Windows screensaver), I’m just making something up.
My usecase is that I have a small ESS: A Multiplus 5000, 3 x 60Ah battery and an MPPT. My battery’s are connected on a busbar to a 120mm2 wire. Still, there are, obviously, some differences in wire resistance. Since when they drain to about 40, 30%, my cell differences start to plummet, and so does my voltage.
Long story short, it doesn’t work exactly as intended yet. This is why I can get through almost a full night, feeding the house through the batteries. But not quite. So in the morning I get a low battery error. I can click this, remotely, as seen. - Sometimes the battery gets charged and drained again, so that is why I get a low battery error a second (or third, fourth,) time.
Other times it seems that I had affirmed the error remotely. But when returning from work etc. And coming in the shed, where my ESS is installed. I notice the screen, GX touch, still is on, on the Alarm/Message tab.
And has been for a whole day than.
Of course the above story is on me, and I still have work to do.
But so that is why I kindly ask if it is possible to implement some sort of screensaver.
Thank you for reading.
I have the same problem with my 50 installed on my boat. I get the notification of an alarm, open the remote console in VRM and acknowledge the alarm, but even after acknowledging it, the screen stays on. I can verify this through a wifi camera I have on the boat. The only way I found to make sure the GX50 screen turns off is to reboot the Cerbo. Quite annoying.
