Guimods -> RpiGpioSetup switch relay output 3
Hello
I have Venus OS running on a RPI and Guimods and RpiGpioSetup are installed there too
I have set up 2 outputs so that I can use them to switch 2 relay outputs on and off using temperature (Ruvvi).
The fan for my 2 MPPTs is also working.
I would like to do the same with my third MPPT.
How can I use the temperature to control a third relay that cools my third MPPT?
Thanks
@Kevin is nothing possible??
Thanks
The logic for temperature alarms recognizes only the first two relays. That code would need to be modified. If I recall, Victron may have hinted they are considering modfying all relay use code to accommodate additional relays but don’t know the time frame.
For my part, I’m unfortunately have no time for any updates to GuiMods or my other packages at this time.
@kwindrem
Hello Kevin
Ok thanks
Can I perhaps use a different Gipo and control it via Nodered for now?
I tried it but somehow the Gipo isn’t being read.
Is this due to RpiGiposetup…
Thanks you
Could be Venus OS takes over the GPIOs used for the relays. You could prevent that by taking the pin out of the /etc/veus/gpio_list. You can specify a custom file in RpiGPioSetup when running the setup script from the command line.
Gipo 3 and 4 are not used in the list
That’s why I don’t understand it!
#### this includes using only the first channel of the WaveShare dual channel hats
#### note that WaveShare sells two different dual channel CANbus hats: the non FD and FD (flexible data rate)
### for use by the RpiGpio package on Raspberry PI platforms ONLY
# This is a list of GPIO pins, set by the script /etc/rcS.d/S90gpio_pins.sh
# They are documented at: bbb gpio · victronenergy/venus Wiki · GitHub
# Format: <pin_number> <direction: in/out>
# The part is used to create an symlink in /dev/gpio.
# relays are active HIGH
# Relay 1 GPIO 21 / header pin 40
21 out relay_1
# Relay 2 GPIO 17 / header pin 11
17 out relay_2
# Relay 3 GPIO 27 / header pin 13
27 out relay_3
# Relay 4 GPIO 22 / header pin 15
22 out relay_4
# Relay 5 GPIO 23 / header pin 16
23 out relay_5
# Relay 6 GPIO 24 / header pin 18
24 out relay_6
# these have pull UPs
# Digital input 1 GPIO 5 / header pin 29
5 in digital_input_1
# Digital input 2 GPIO 6 / header pin 31
6 in digital_input_2
# in stock code these have pull DOWNs
#### modified to pull UPs by the GPIO overlay that is installed as part of this package
# Digital input 3 GPIO 13 / header pin 33
13 in digital_input_3
# Digital input 4 GPIO 19 / header pin 35
19 in digital_input_4
# Digital input 5 GPIO 26 / header pin 37
26 in digital_input_5
#### Gracefull shutdown input
#### Note this input is NOT added to the available I/O used by Venus OS !!!
# GPIO 16 / header pin 36
16 in digital_input_6
