Hi everyone,
I’m using Node-RED on a Venus OS system to monitor the grid frequency via a Grid Meter (com.victronenergy.grid/31
, path /Ac/Frequency
I’ve noticed that the frequency values now only change in 0.05 Hz steps, for example:
49.95 → 50.00 → 50.05 → 50.00 → ...
Previously, these values were provided with higher resolution, such as 49.97 or 50.02 Hz. May be OS 3.6.
The Node-RED flow is correctly configured to display two decimal places, and I’ve confirmed via a debug node that the values are already rounded when received from D-Bus. The Grid Meter itself likely provides more precise data internally.
I suspect this change may have been introduced in a recent Venus OS version or within the dbus-gridservice
, possibly as a form of smoothing or rounding.
My questions:
Was this rounding behavior intentionally implemented?
Is there a way to access raw, high-resolution frequency values again?
I’m using the frequency values to track daily min/max levels, and this rounding significantly reduces the detail of those measurements.
Thanks in advance for any help or clarification!
Best regards,
Ronald
