Get dynamic prices from VRM in Node-Red
Hi all,
I would like to get the current energy price in Node-Red to switch off the MPPT’s when dynamic energy prices are negative. I’ve found multiple option to use the VRM API node, but can’t seem to get the current energy prices. I tried the below:
This gives me no information with the debug node.
This gives me some information, and looks like it shows me 0,25 euro per kWh for the whole day which is not correct.
Anyone got this working and how?
Thanks!
If at all possible, I’d advise to first check whether your energy supplier provides an API to get your prices (and much more) data. I know in NL how to do that for Tibber and for Zonneplan. And if you want them from Victron, I can state with certainty that this is possible, usually with upto an hours delay, and discussed so much on this forum already, that you should really be able to figure it out using the search function. Try how far you get by yourself, share where you get stuck and why, and you’ll surely find help on this forum.
This how I turn of mine Enphase system:
