I am trying to switch a DC-DC Orion using the generator start stop function. I can make it work manually, so if I start and stop the generator manually it works. I am running a duel voltage system in a Motorhome using 2 shunts, I would like to cycle the 12v battery so it is not constantly being charged, so allowing it to drop to 30% and then recharge it using the 24v battery bank. I have tried manually changing the battery SOC on both shunts with no joy. I have set the 12v shunt as the principle shunt so I am hoping the start stop function will be looking at this shunt. I must have the relay connected correctly as I can operate it manually using the GX touch. Any ideas???
Related topics
| Topic | Replies | Views | Activity | |
| Generator start stop does not work as it should? | 13 | 124 | 3 February 2026 | |
| Generator sometimes does not stop when reaching SOC stop condition | 7 | 245 | 18 January 2026 | |
| Generator Auto Start questions. Using Voltage and SOC% | 0 | 80 | 23 January 2026 | |
| Generator start stop parameters not being met and generator restarts | 0 | 40 | 2 March 2025 | |
| Generator start stop function Cerbo GX and Quattro working irregular | 0 | 76 | 21 April 2025 |
