GbbOptimizer (a professional DESS alternative)
Version 14.3 https://gbboptimizer.gbbsoft.pl/
  • Added support for Supla/Toya meters to import real EV charger or heat pump consumption
Now you can use Token created in VRM instead of login/password.
Version 14.4
  • Optimizer based on prices: new option: Don’t discharge battery while EV will be charging
Zrzut ekranu 2024-09-30 200856 EN
How do you know that an EV is charging?
With the Supla/Toya meters from 14.3?
Additionally, you are saying:
Victron: You must have connection with VRM
Import EV charger energy from Victron
Is this EV information sent from Cerbo to VRM?
Thank you!
  1. Program must know they you WILL charge EV, so you enter this information into program in EV menu. This information is used later in Optimizer.
  2. After charge EV program can get this information directly from VRM or from Tuya Or Supla meters.
So, in fact the program knows that in a certain time interval (HH1:MM1 → HH2:MM2) defined by the user you have the EV scheduled to charge and it doesn’t charge or discharge the battery in that time interval?
And you measure the energy at the beginning of the interval and at the end of the interval and then, by difference, know the energy absorbed by the EV?
Future and optimalization is one thing.
Past and real data is different thing.
Future you enter to program. Based on it optimizer optimizes charges and discharges.
Past program gets from meters (if you haven’t meters there are some other solutions, eg. AutoConverter which changes hight Loads to EV)
Thank you for explanations.
Now, after this topic, I understand a little bit more.
:+1:
Version 14.5 https://gbboptimizer.gbbsoft.pl
  • New simplified way to setup Heating Pump parameters.
Version 14.6 https://gbboptimizer.gbbsoft.pl/
  • Victron/Deye+Solarman: new special option: Disconnect from grid when nothing to do: (a) no PV, (b) no battery charge from grid, (c) no battery discharge to grid, (d) SOC>MinSOC and (e) no EV charge
Version 14.7 https://gbboptimizer.gbbsoft.pl/
  • Optimizer based on prices: new option: Block discharge if difference between sale amount and purchase amount in the next 12 hours (not 24!) is less than X
Zrzut ekranu 2024-10-12 170518 EN
Version 14.8 https://gbboptimizer.gbbsoft.pl/
  • Meteorological alerts: it is possible to link the occurrence of a meteorological warning of a specified type (e.g.: wind) and level (e.g.: severe) with the enforcement of maintaining a specified high SOC in the batteries for the duration of this warning (via a optimizer based on prices). The data comes from MeteoAlarm (Europe) or IMGW (Poland)
Version 14.9 https://gbboptimizer.gbbsoft.pl/
  • Charge limits: You can now specify the SOC level at which the charging limit will apply
Version 14.10 https://gbboptimizer.gbbsoft.pl/
  • Optimizer based on prices: new option: Don’t sell more than PV production in last 24h
Version 14.12 https://gbboptimizer.gbbsoft.pl/
  • Optimizer based on prices: new option: Try forecast more than only 24h (up to end of prices, eg. end of next day)
Version 14.13 https://gbboptimizer.gbbsoft.pl/
  • menu IoT: added the ability to add meters (e.g. heat pumps) connected directly to Cerbo in the Victron system
Version 14.15 https://gbboptimizer.gbbsoft.pl/
  • You can now set different grid import values (Deye+Solarman=Grid Peak Shaving) for different hours
Version 14.16 https://gbboptimizer.gbbsoft.pl
  • New option to disconnect from grid when: there is not charge battery from grid, discharge battery to grid nor EV charge. (Victron or Deye+Solarman)
Fast price change when price suddenly is different then from price source.
Version 14.17 https://gbboptimizer.gbbsoft.pl/
  • New source of prices: Amber from Australia
