Fronius gen24 primo not showing all info under Venus os
Hi Can anyone help or advise i have venus os running on a small solar system no problems but have had a solar system 3.5 kw installed using a fronius gen 24 primo inverter which the venus os has detected,but has detected it as a fronius Tauro not a gen 24 ,also it is showing the wattage it has produced plus the wattage in real time it is generating but no voltage or current etc do i need to add some more software to the venus os.
It detects serial number and id but not the fronius data logger this is all through wifi and the api is turned on under the fronius setting.
Any suggestions thanks
