frankvdl
(Frank)
1
I want to configure my converter using MQTT to forcefully discharge the battery.
Currently I’ve set
settings/0/Settings/CGwacs/Hub4Mode to 3 (External Model)
settings/0/Settings/CGwacs/AcPowerSetPoint to -1000
But if I do this, the converter returns to an ‘inactive state’
What am I missing ?
nickdb
(Nick)
2
Just set the inverter software switch to invert only. Job done.
frankvdl
(Frank)
3
How can I do that using MQTT ?
What is the topic and value i need to set
nickdb
(Nick)
4
To be clear are you wanting to force discharge into the grid or loads attached to AC out?
And is this a managed battery?
frankvdl
(Frank)
5
yes I want to discharge into the grid.
What do you mean with a ‘managed’ battery ?
Disable DESS and
W/c0619ab58c9b/settings/0/Settings/CGwacs/AcPowerSetPoint
Change c0619ab58c9b to yours
I use MQTT Explorer (for test)
And check
