Flow to disable feed-in and charging
Gave it a try, now I could find functions to disable MP2 feed-in or battery charge depending on battery SOC and injected power to the grid : no feed-in whenever grid power is below -2000W (should already be the case using ESS with 0W target, but for some reasons, is not) - and no battery charge using a junction combining SOC and grid power (the more power injected to grid, the higher SOC allowed to charge up to, namely 100% at -8000W down to 50% at 0W). Seemed to work at first but with strange behavior, like discharging when it should not (ie no feed-in), “passthough” state seen on MP2, and now completely stuck with “referenceError, context not defined” - I had to use context to store payload from messages so as to be able to combine them and create message to MP2.
Now I understand a bit better Node Red, my functions seem ok to set “disable feed-in” and “disable charge”, but still the MP2 state seen on the dashboard sometimes changes from “external control” to " Discharging" (with low power between 50-100Watts) and then “Passthrough” (with no discharge).
        "id": "a1878c92aa203952",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "4a934764ca949cbe",
        "type": "victron-input-vebus",
        "z": "a1878c92aa203952",
        "service": "com.victronenergy.vebus/275",
        "path": "/Ac/Out/L1/P",
        "serviceObj": {
            "name": "MultiPlus-II 48/3000/35-32",
            "communityTag": "vebus"
        "pathObj": {
            "type": "float",
            "name": "Output power phase L1 (W)"
        "name": "Grid_power",
        "onlyChanges": false,
        "roundValues": "no",
        "rateLimit": "0",
        "outputs": 1,
        "conditionalMode": false,
        "outputTrue": "true",
        "outputFalse": "false",
        "debounce": "2000",
        "x": 310,
        "y": 340,
        "wires": [
                "e793cd3799bf40e5",
                "0ae4d2f49d2376db"
        "id": "57d182b120d4fdca",
        "type": "victron-input-battery",
        "service": "com.victronenergy.battery/512",
        "path": "/Soc",
        "serviceObj": {
            "name": "JK-BMS",
            "communityTag": "battery"
        "pathObj": {
            "path": "/Soc",
            "type": "float",
            "name": "State of charge (%)"
        "name": "SOC",
        "rateLimit": "1",
        "outputs": 1,
        "debounce": "2000",
        "x": 310,
        "y": 520,
        "wires": [
                "edee4111305ff472"
        "id": "ceada869b0725cfb",
        "type": "victron-output-ess",
        "path": "/Hub4/DisableCharge",
        "serviceObj": {
            "communityTag": "ess"
        "pathObj": {
            "type": "enum",
            "name": "Disable charge",
            "enum": {
                "0": "No",
                "1": "Yes"
            "mode": "both"
        "name": "",
        "rateLimit": 0,
        "outputs": 0,
        "condition1Operator": ">",
        "condition2Enabled": false,
        "condition2Service": "",
        "condition2Path": "",
        "condition2Operator": ">",
        "logicOperator": "AND",
        "outputOnChange": false,
        "debounce": 2000,
        "x": 910,
        "y": 380,
        "wires": []
        "id": "b3a93f1167f77fbf",
        "path": "/Hub4/DisableFeedIn",
        "serviceObj": {
        "pathObj": {
            "type": "enum",
            "name": "Disable feed-in",
            "enum": {
                "0": "No",
                "1": "Yes"
            "mode": "both"
        "name": "",
        "rateLimit": 0,
        "outputs": 0,
        "debounce": 2000,
        "x": 910,
        "y": 320,
        "wires": []
        "id": "e793cd3799bf40e5",
        "type": "function",
        "name": "function 1",
        "func": "if (msg.payload < -400)\n  msg.payload = 1;\nelse\n  msg.payload = 0;\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 540,
        "y": 320,
        "wires": [
                "b3a93f1167f77fbf"
        "id": "0ae4d2f49d2376db",
        "type": "function",
        "name": "function 2",
        "func": "// msg has grid_power and mySOC has SOC stored\nvar gp = msg.payload;\nvar SOC = flow.get(\"mySOC\")||0.5;\n\nif ((SOC + Math.min(0,gp/20000))>0.5)\n  msg.payload = 1;\nelse\n  msg.payload = 0;\n\n//msg.entity = \"f2\"\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 540,
        "y": 380,
        "wires": [
                "3cc50a647b88c759",
                "ceada869b0725cfb"
        "id": "edee4111305ff472",
        "type": "change",
        "name": "storeSOC",
        "rules": [
                "t": "set",
                "p": "mySOC",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 460,
        "y": 520,
        "wires": [
        "id": "3cc50a647b88c759",
        "type": "debug",
        "name": "debug 1",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 840,
        "y": 480,
        "wires": []
        "id": "13c77840f94ebb7f",
        "type": "global-config",
        "env": [],
        "modules": {
            "@victronenergy/node-red-contrib-victron": "1.6.64"
Now I think the Node Red function work and allow charging slowly batteries upon largest feed-in time, and discharging at night to keep 0W coming from grid. But still the Fan turns ON during the day when feed-in is above approx 7kW, and independant of charging enabled or not (and anyway, charging with up to a few 100s of watt should not require fan). This is with v558, so I suspect there is still a bug with fan behavior.
Maybe there is a way to log things more in detail to check what is going on. I do not like the idea of adding unnecessary wear to a device that should work 10 yrs at the very least, especially when I set it to remain far from its power limits.
