Float knippert oranje VE. Bus error [276] rotation error
I have 3 multiplus 3000 in a 3 phase configuration (single phase input, 3 phase output) in a Dutch situation. I have e float error (orange led blinking) and a VE Bus error 276 Rotation error. I tried to switch L1 and L2 in the software (switching two multi’s). But no effect. Do I need to change the wiring to get rid of this error? Or is the 1 phase input and the 3 phase output not possible? Thanks in advance.
Dont think its possible, but maybe if u turn off switch as group in ve bus configurator
If it works one multi can only charge/discharge and the other two are always discharging…
