After 3+ years of full time, off grid use my system went haywire during normal operation.
I have a Quattro 24v/5000W, with cerbo, 3mppts, and 3 Simpliphi batteries totaling approx 10KWhr of storage. Firmware on the cerbo is 3.41. Firmware on the controllers is 1.64
I experienced a low battery alarm and system shutdown during the day with full sun, inverter running at 75% capacity, and near fully charged batteries. Voltage readings on Bluetooth victron connect were reading 26.7V. However when I manually cycled on/off switch on inverter, it would immediately shut down again with another low voltage alarm.
At that point, I placed a voltmeter on the DC leads at the Quattro and detected that the voltage was being drawn down quickly after inverter restart. I assume the sample rate of the victron Connect was not frequent enough to pick up the sudden drop In voltage. All AC loads were removed and i cycled the inverter again. I got the same result. The magnitude of the voltage drop was large and seems to point to a dead short.
Next, I isolated the individual batteries one at a time to determine if I had an internal short in one of the batteries. All seems good with the batteries
I am now getting flashing LED lights on the Inverter with two slightly different sequences. I have inserted links to YouTube videos below. Note that the noise in the background is a generator running.
And finally, I am unable to detect or check my VE Bus configurations via the web. Previously all was working fine with respect to the communications and web access
The CAT 5 cable from the Cerbo to the Quattro appears to be fine
All of this occurred suddenly. There were no recent changes to the hardware or software. The system was operating normally until it wasn’t.
Currently, I am thinking my Cerbo went bad. Or possibly there is a short in the Quattro that is drawing down the battery voltage.
Thank you in advance for your thoughts on how to troubleshoot this.
Videos of LEDs Flashing:
(https://youtube.com/shorts/5F4e1QTiszg?si=oQkJhzxg332cH00n)
[https://youtube.com/shorts/8RdrCrKTg4w?si=daVrJt-BrNWOmlAY]
