Feature Request - VRM Graph Suggestion Forecast SOC
It would be greatly appreciated if the forecast battery SOC line which appears when you use DESS could also appear on the overview graph when DSS is not used, the forecast consumption and PV bars are there so it should be easy? to add it.
I’m not using DSS as I have a Node Red setup but it would be nice to see the forecast SOC line
Many Thanks
