Feature Request: Timed SOC Configuration for Optimized Energy Management
Dear Victron team,
I am an African user of your products for over a year now, residing in Mali, West Africa, where we are currently facing significant electricity problems. I have two Multiplus 5kVA installations, one at home and one at the office, and a third 10kVA installation at a friend’s place.
Our main issue is that we cannot sell electricity back to the grid operator, and we experience power outages at random hours. We only get between 6 and 7 hours of electricity daily. Given the high cost of Victron equipment and batteries in our region, it would be great if we could configure your system to optimize energy savings without risking battery depletion.
I have looked into configuring an automatic switch between the building’s power sources (grid input and batteries) intelligently but could not find a way to do it. Here’s a configuration option that would be very useful for us:
Could you add a feature in your software that allows users to specify the minimum state of charge (SOC) for each hour of the day? For instance, let users define parameters like the following:
00:00:00 - 00:59:59 --------> min SOC = 60% (user-provided value)
01:00:00 - 01:59:59 --------> min SOC = 50%
02:00:00 - 02:59:59 --------> min SOC = 45%
03:00:00 - 03:59:59 --------> min SOC = 40%
12:00:00 - 12:59:59 --------> min SOC = 70%
23:00:00 - 23:59:59 --------> min SOC = 65%
The advantage of this configuration is that it allows us to draw only the minimum power we need from the grid while ensuring the batteries remain sufficiently charged for evening use.
Currently, since we do not know when electricity will be available, all we know is that it will not exceed 7 hours a day (and often as little as 4 hours), we are forced to manually change the SOC settings repeatedly to save energy and prioritize battery consumption.
I remain available for any questions at my email address.
Thank you!
This battery control already possible with node red on venus os large.
Mixing grid and solar is very possible using ess as well.
Power outages are a very common thing definitely in Africa
Hi. Would like to do a setup similar to this - is this possible through something via VRM on ESS or somewhere else? Have no experience with Node Red but willing to try if no other way…
You need to use nodered.
Thank you - crash course here we come…
@JCD on their yourtube channel Victron have a beginners guide. There is also a nodered for dummies post on the dedicated nodered category on this forum.
Brilliant - thank you
