Extra inverter as DC system in a 3phase system
Hi, been breaking my head over this for a while now.
I have a Multiplus-II 3 phase configuration, works fine. Now I would like to add another multiplus-II as a separate DC usage system to create an additional mini-grid for extra usage of high powered pyrolysis oven (around 3.5KW) continuously.
Now to prevent overloading up my 3phase configuration which I use for my household appliances, I was thinking of adding my spare inverter as a DC usage system. Not a problem of course, just disable the charger in the unit and let it only invert DC to AC.
Now comes my thing that I cannot figure out: Can I connect this new separate inverter to my existing Cerbo-GX and have the system see it as a separate inverted or will the system get so confused that it will break?
Secondly, is adding this single inverter as a DC usage system a good idea to have additional power in stead of adding 3 extra inverters in the 3 phase system?
Any help or pointers to think about would be appreciated much.
Hi Ivan, I used an extra Cerbo GX with an extra Multiplus II/48/5000 in addition to my 3phase configuration of 6 Multiplus II/48/3000 to have my heating pump running from my pylontecs.
you have to loop thru the BMS cable from one Cerbo GX to the next Cerbo GX. all works fine.
I did realize in February 2025.
thnx for the tip. Will surely consider this option.
Hello ivan.cavanaugh, were you able to try it out? If so, could you kindly share your experience?
