External Transfer Switch application for Quatro
I was looking at the “MultiPlus-II External Transfer Switch application” documentation and was wondering if that option would be available for the Quatro Inverters? I am in the United States so I would need a 120v inverter. The largest 120v Multiplus-II is 5000 VA and for some of my larger systems I would like to use the Quatro 10,000 VA Inverter.
Here are some links to the “MultiPlus-II External Transfer Switch application” documents.
https://www.victronenergy.com/media/pg/MultiPlus-II_External_Transfer_Switch_application/en/inde
Like many of Victron’s products, this isn’t meant for us in the USA. Is your interest in this to reduce the AC wiring? I think this solution is meant for some of the Euro Multi’s inability to run in parallel. I guess, in short, what problem are you trying to solve? :slight_smile:
Yes I was thinking it would save on wiring and simplify larger systems. We installed a 40kva system in split phase 120/240v with x4 Quatro 10ks last fall and might be installing another system like that in the future.
Hey did you ever get an answer on this? I was wondering the same thing. :grinning_face_with_smiling_eyes:
